Building Integrity
Date:  8-24-2014
Number of Hours:  3.00
Manual Reference:  ch 22
Brief Description:  Hardware install and hwy cleanup
I feel like a turtle compared to Harrison Avionics when it comes to speed of assembly. Tonight I wanted to start tightening up the paths of wires and replacing Adel clamps that were too small for the bundle that needed to be inside. I replaced at least 5 not knowing there would be so many wires with a VFR Panel like mine. But then you add the iLevil, Engine Monitoring and a VPX and all of a sudden it's a KING Air Wiring mess :)
I routed and placed the GPS antennas where they will be installed above the VPX. Here they will have a nice clear view of the sky. I then installed almost all of the Panel hardware so switch wiring and remaining harnesses can be finished easily this saturday by Harrison.
One thing I've noticed is that I have no choice but to extend the conduit used for the rudder cables. The vertical wire bundles are too thick for the cable to clear so I'll need to tackle this issue before the radio rack gets installed and things get too tight to work inside there. More later!
Panel hardware installed
GPS antennas located
Wire bundles cleaned up
