Brief Description: VPX install, wires n highways..
Ok, I'm really liking this wiring business. I am following the path that the brake lines take through the nose and installed adel clamps right above the brake line. Large 3/4" clamps should be plenty to house all the wires coming up the fuselage sides. I started running the power and ground wires for the OAT, Speed brake, Heated seats, and fuel pumps. All getting a ground wire to the main ground buss, and a power wire to the VPX. This VPX is just so simple to use, it will be in every airplane I build...oops.. does that mean I'll build another one? LOL. I also added smaller plastic adel clamps over the area right behind the nose hatch that will act as a highway for any wires that need to cross over to the other side. This keeps them hidden from view as well. Labeling all ground wires for future maintanence is a must. When all the wires are finished being run, a plastic conduit will house them all along the sides to protect them from wandering feet.
