Building Integrity
Date:  3-12-2014
Number of Hours:  7.00
Manual Reference:  ch 18
Brief Description:  Latch hardware install
Today's goal was to install all latch hardware with 5 min flox in prep for a much wetter flox that will later be added using EZ Poxy. I went ahead and cut the heads off of 2 an4 bolts, rounded the ends and left a section of threaded area for bonding inside of the canopy frame. I also accounted for the expansion that I saw last summer on a really hot day. I wanted to make sure that the canopy pins stay inside the receiver at all times. I placed the pins inside both receivers, and drilled a 1/4" hole on both sides of the canopy rails. I was pretty much dead on so an oversized hole wasn't needed and when floxing upside down this helps. I cleared out the foam inside the canopy rails and pressed in some 5 minute flox. I also drilled a small hole ABOVE the rail to allow venting and an access to add more flox later to ensure the entire cavity is full. Moving quickly I jumped inside the cockpit, closed and latched the canopy while the flox set up. ALL is well.
Next was the latch pins to secure the latches and offer a partially open canopy position for taxi. I used the same process here to mark my holes, but found I could use a CLECO with the tape to hold the entire assembly in place during cure. When finished, a locking ball pin will slide inside the assembly for both taxi and in flight security. Making the parts took some time because I wanted a polished and precision made part so today was a solid 7 hours for both of the hardware tasks.
The canopy works well so far, but full testing wont happen till that wet flox is added for strength. Stay tuned!
Canopy alignment pins
pins in receivers, ready for flox
pins in position
pins in position
