A 1" length of both 3/4" and 1" aluminum tube was fitted over the Canopy Cam Locks. both were sanded to 220 grit and floxed inside the longerons and hardpoints. I drilled out the hardpoints using a hole saw, drill bit, and sanding drum. The Cam locks were coated in vaseline before inserting them into the aluminum tubes which will cure inside the longerons and hardpoints overnight. I am VERY pleased with the installation and look forward to testing them out.
Note: The extra length of material shown in pic #3 will be cut off after cure.
