Brief Description: Carving Foam and latch hardpoints
The Latches I'm using are identical to what the berkut uses. Simple design and awesome :D I used a 3/4" piece of Red Oak to construct the 2 hardpoints needed for the Cam to go through. A 1" hole was bored through the oak and then the triangle pieces cut out. I then bonded them to the longerons 7" back from the panel and laid up 2 plies of BID over both and 1" onto the fuselage and longerons. While this was set to cure I carved out the foam on the inside of the canopy in prep for future glass work.
