The canopy has been removed for the addition of the hinges. The hinges a little play in them which I first thought would be a problem, however seeing that the construction is robust 316 SS, I will lube them and let the play help reduce wear in the event that my geometry isn't perfect. The nicest thing about this hinge and strut setup will be that they will be completely concealed from view, both inside and out when the canopy is shut. Real nice :)
