This 3in1 primer from TP Tools is just amazing stuff. Nothing wrong with epoxy primer but when time is limited, you just can't beat the 2k stuff. High build, quick cure, and easy to sand. The left wing now has it's first and second to last round of primer on the topside which consists of 3 coats which will be block sanded on monday before final primer is applied. It's looking like this wing should be finished by Wednesday and then on to the other. Good times ;)
