Now that I've been running a new hotter plug, it seems I've found the solution to the infamous UL Power fouling issue. The new FR6DTC plugs are only 1 temp range hotter than the OEM plugs and run much cleaner with NO sign of pre-ignition or detonation whatsoever. Instead of black, carbon fouled plugs needing to be cleaned every 10 hrs, I now have light brown/grey plugs all around EVEN when running the engine without the lean mod. I highly recommend all UL Power engine owners switch over to this plug!
