Building Integrity
Date:  7-13-2018
Number of Hours:  1.00
Manual Reference:  Section 2
Brief Description:  20hr Compression test results
After biting off all my nails, I got the courage to go ahead and do a compression check on all 6 cylinders. I was nervous about the #6 cyl as it was only 2 hours new, and also #2 because the head was just installed. BUT, every cylinder was fantastic, and this was done on a COLD engine!! Here are the results:
1. 79/80
2. 78/80
3. 79/80
4. 79/80
5. 79/80
6. 77/80
As you can see, the only ones under 79 were #2 that needed a valve adjustment, and #6 that isn't anywhere near broken in yet and STILL well within acceptable limits. Again, being cold, these numbers only PROVE that a proper breakin is crucial for a happy running engine.
20hr compression test complete
