Brief Description: Wing sanding and prep for primer
5 hours of nasty block sanding on the wings today in prep for applying the white primer. Lots of detailed taping as well. Good news is that she sits ready for primer. I'll most likely apply 3 coats, block sand again, then add 2 more coats before final sanding to 320 grit. Here's to good luck on my side!
