Building Integrity
Date:  12-12-2017
Manual Reference:  ch 22
Brief Description:  Relocation of the OAT sensor
The new location for the OAT sensor was back to the same fresh air vent it was in originally. I debated other locations but knowing how well this has worked I wanted to keep things the same if possible. And to my surprize, the wire length of the OAT probe was just enough to re-route around the nose to the new location I installed the fresh air vent. Perfect! Being that I use a thousand zip ties throughout, I had a lot of re-zipping to do which takes some time. I then was able to solder the new, longer ground wire to the original ground terminal and she is done! Now as soon as my new CAT tubing arrives I'll replace the rediculous orange stuff for some much better matching black tubing. After that, all the avionics will go back in and this interior nose job will be done. I also took this time to hard mount my Pitot Static line connections to the sidewalls as well as one of my GPS antenna wires that was flopping around. Much cleaner and more organized. Worth it!
OAT temp probe installed
Soldered ground wire connection complete
