Long Ez: Building a Dream
Date:  6-9-2012
Number of Hours:  0.10
Manual Reference:  ch 4
Brief Description:  Adding Micro
Most likely I will end up using an aluminum panel, making half of this work pointless, but because I can't see into the future I thought I'd play it safe and do the work in case things change. Here I simply spread micro over the 2 layers of Bid that covered the nose wheel window and former nose gear manual crank hole.
