Long Ez: Building a Dream
Date:  5-15-2012
Number of Hours:  1.50
Manual Reference:  ch 17
Brief Description:  Roll trim construction
I have concluded that I won't be doing exactly what the plans say concerning the roll trim setup. Instead I will be cutting off the trim lever right after the spring attach hole and then using a titanium pushrod and ball joint for trim application. The rod will connect to an aluminum arm that is mounted to the top of the armrest. The lever will bank side to side from birds eye view creating a very sleek trim lever. more on this later...
Parts used on radio control airplanes :)
