Modified firewall grommet. Installed wire run conduit within the center section assembly. Installed antenna cables, tunnel harness, and phone line for ELT. Installed and connnected CPU fans to the harness. Attached Flo-Scan to the harness. Attached fuel pump wiring to the harness.
