Ebby's Hatz Classic
Date:  3-10-2006
Number of Hours:  2.50
Brief Description:  Cowling-forward instrument panel
I test fit the flange for the upper part of the forward instrument panel. The need for a metal stretcher once again appears. Bending the tabs back allows the top edge of the flange to be parallel with the cowling cover. A bit of stretching would be good but I believe the anchor nuts will draw all the pieces together. Each tab is flush riveted with a 1/8" AD. Unfortunately the flange is too deep so I could not use the squeezer.
