Now comes the alignment problem. I decided to use a piece of drill rod clamped into some white oak blocks to align the bushings for the wing attachment points. The wooden block were marked with the plans dimensions in black ink then drilled for the longeron and drill rod. I slipped the two bushings over the drill rod and built the wing attachent fittings out to them.
