Brief Description: Truing the fuselage with pipe clamps
Clamping is an artform in a way. I found that many different types of clamps are needed to hold things into place. Many clamps are purchased several are custom made. Here a pipe clamp is used to hold all the tubes together at the firewall. Four tubes meet at a common point on the "lower" cross-tube at the firewall. What a cluster to make!
