Brief Description: Welding in bushing for engine mounts.
I made a drill jig 90 degrees to the surface. A pilot hole was drilled then a unibit widened the hole to 5/8". The bushing is flush in the front and not welded. On the back side there is extra length in the bushing and welded in place.
