Ebby's Hatz Classic
Date:  6-19-2005
Number of Hours:  4.50
Brief Description:  Fuel Shutoff Bracket
Originally I was going to have a main tank and a header tank. Then thought a 28 gallon main tank would be plenty as the endurance would be nearly 4 hours. So one main tank it is. The support is 1/4" tubing and .050" bracket. The bracket was made from a tracing held against the valve. Additional guides for the shut-off shaft were welded to carry the shaft back to the pilots cockpit.
Support welded
Support welded
Bracket welded
Bracket welded
Valve temporarily in place.
