There is a lot of assemble/disassemble in cutting and fitting the diagonals. Eventually the side begins to take shape. When a tube has a smaller diameter than the longeron, it is necessary to prop up the tube with a spacer so the centerline or axis of
Welding rod used as a prop to keep centerlines equal.
