Ebby's Hatz Classic
Date:  2-27-2005
Brief Description:  Landing Gear Attachment point
Back to making the forward gear leg fitting. Using the aluminum pattern I cut four teardrop shaped supports. Tack welded bushings to the bent supports and found the two reinforcement straps I made earlier. These are all the pieces needed to finish off the upper main gear leg.
