Brief Description: Setup for top and bottom of fueslage.
Both sides of the fuselage are tack welded. Image one shows the two sides in the background. I went about cutting a series of spacers to fix the distance between the two side. These were made from half inch CDX and had tube blocks screwed into the ends at the specified distance of twenty six inches. I used these spacers for many other parts of fuselage fabrication.
