Here I am again this time it's new years day. No hangover!! The bushings are reamed to final size. The upper mounting pads are done using a roll wire fitting. The angle of the roll wire fitting is taken off the plans sheet. Tack welded and the finish welded. A tremendous amount of work goes into these four corners of the airframe.
