Brief Description: Landing Gear Washers for struts
1/8" 4130 plate was cut into squares and mounted to a piece of wood. This was clamped into a vise and drilled with a bi-metal hole saw. The smaller hole was drilled first then the outer hole. There is a very sharp edge left on the bottom of the washer that needed to be filed off.
