Ebby's Hatz Classic
Date:  2-11-2004
Number of Hours:  1.00
Brief Description:  Push Tube Square End Fitting
I'm still not sure how a square fitting will go onto a round tube but I should have it figured out by tomorrow. A 9/16"hole was drilled on opposite sides and the web steel was cut out with a dremel fitted with a cut-off wheel. The back of the fitting wa
