Brief Description: Stop Washers for Landing Gear Springs
.125" plate was mounted on oak backing blocks. These blocks were clamped to the drill press table and a bi-metallic hole saw was used to cut the first hole. A larger size hole saw cut the finished size. The flash was dressed on a belt sander. The disk
