Brief Description: Elevator Horn shaped and drilled
The two pieces were clamped together and the edges sanded to final shape. The pattern was used to mark the hole location. A drill press was used to drill the holes except for the larger hole which was done with a joint jigger. A "gate" will be cut in t
