Brief Description: Cutting fishmouth with joint jigger
This is a knockoff of the joint jigger at about half the price. I totally disregarded the measurement scale, drilled additional holes in the back plate to cut sharper angles and at times reversed the clamp that holds the tubing secure. Instead of using
