Ebby's Hatz Classic
Date:  2-19-2004
Brief Description:  Forward bearing stops.
This idea came from Makelan. clamping four short pieces of tubing between the washers before tack welding. It was a great idea but I forgot to add a small wafer of metal at each of the four tubes to give a bit of clearance when slipping the tube over th
Use a small wafer of metal + the tubes as spacers.
The entire outer joint was filet welded.
So far so good.  A lot of places to foul up.
