Ebby's Hatz Classic
Date:  2-16-2004
Brief Description:  Making a torque tube flange
Two of these flanges need to be made. One for each cockpit station. After the initial bend, the flange is tack welded to a scrap of tubing the same size as the torque tube. A torch is then used to heat the tabs to an orange or until the metal becomes p
Flange is positioned on scrap tube.
Using A/O heat to orange and mold around tube.
After true and level tack weld flange to tube.
