Brief Description: Installing bearing blocks and supports.
I messed up one of the UHMW blocks while drilling so I made a new one. I discovered that it was a lot easier to drill the 1 1/2" hole while the UHMW was clamped into the support bracket. A slow speed was selected on the drill press. A small drum sande
Drilling out the UHMW PE to 1 1/2" while in the clamp.
