Two support stantions are fabricated from .049 rectangular stock. The two supports are fitted to create a 1.7 degree slope of the torque tube. The bearing block plates could have been made a bit wider as the welding along the long edge was tricky in tha
Stock is held in place and marked for fit.
Torque tube supports welded to the bushing plates.
