Began assembly of control cables for the elevator. This is required to set the controls at the nuetral position so the elvator control rod, which attaches to the stick, can be measured and cut for final fit. Made up the 2 cable bridles with turnbuckles and attached to the elevator bellcrank. I borrowed a Nico-press swedge tool to make up the cable ends.
