Brief Description: left wing bottom skins, nose skin, trailing edge
I decided not to use the sawhorse method and have moved the wing back to the table to have a better means of securing the wing and keep things level & true. Drilled out bottom skins, installed & drilled out nose skin, drilled out main & rear spars. Installed trailing edge skins, drilled out, installed flaperon brackets & drilled out. Ready to disassemble/deburr/corrosion protect/reassemble and rivit.
