Brief Description: Battery, Ignition wires, voltage reg.
This work occurred between mid-May and June 5th. Installed battery and mount, installed voltage regulator, capacitor, main solenoid and starter solenoid. Hooked up starter and alternator. Installed ignition wiring harness and wire caps for magnetos. Secured wiring with adel clamps.
Most of my avionics and instruments have arrived. Will begin on their installation next. Still need to complete fitting up the cowling, will have to add a "teardrop" blister to the top cowl to provide clearance for the pilot side front cylinder spark plug.
