Turned the right wing over, confirmed level & true, and clecoed the top skin, fuel tank skin, and trailing edges to frame. Clecoed the flaperon brackets in place. Drilled out to A-4 the top skins. Clamped the trailing edge to 70 mm from flaperon brackets to rear edge, clamped in place. Drilled out trailing edge to A-4. Rechecked spar for level & true, drilled out main spar and top skins to A-3. Ready to roll up nose skin, will have to wait for some help.....my wife is asleep.
