Brief Description: Preparing HS Parts for Assembly Part 1
With the skins still clecoed to the HS structure, I deburred all the outside skin holes using my electric drill on slow and a deburring bit. This worked amazingly well. After that was time to take everything apart for deburring, dimpling, and priming. I also match drilled the last of the front spar holes to the doublers and reinforcement plates. I then finished today with deburring the spar doublers.
