Today I had my welder come and tack tig weld the I-Struts into position. Also had to put a slight bend in the aileron idler arm (5 degrees) to allow clearance of the aileron push tube with the anti-drag wire. Did this by putting a cut in the arm, bending then re-welding. Worked very well.
