Brief Description: Welding lower rear spar attach brackets to fuselag
Cleaned up the epoxy paint from the area on the fuselage where the lower rear spar attach plates will be welded. Had a third party TIG weld the brackets into position. Tack welded with wings in-situ then removed wings and finish welded. All major welds such as this will be x-rayed for integrity before finishing the fuselage.
