Jon's Skybolt Project
Date:  4-9-2016
Number of Hours:  1.00
Brief Description:  Tack weld I-Struts
Today I had my welder come and tack tig weld the I-Struts into position. Also had to put a slight bend in the aileron idler arm (5 degrees) to allow clearance of the aileron push tube with the anti-drag wire. Did this by putting a cut in the arm, bending then re-welding. Worked very well.
Tack welding the I-Struts
Putting a bend in the aileron idler
Freshly tack welded I-Strut!
