Laser levelled the lower wings to 1.5 degrees angle of incidence and 1 degree dihedral. Made up a cardboard template to locate the 1/4" hole for this fitting and then drilled and reamed to 1/4". Temporarily attached this fitting to check alignment etc. Fitted very well. Will need to weld this fitting now.
