Used the laser level to level the upper wing. The plans call for an angle of incidence of positive 1.5 degrees so I set the fuselage at 1.5 degrees down so that I can level the wings. To do this, I made some exact length wood tags that were clamped to the centre line of each spar. The photos show that the laser was then used to level the wing. Also checked the tailpost to wingtip distance and each wing is within 1 millimetre.
