Brief Description: Glued the aileron cove trailing edge
Glued the aluminium trailing edge to each aileron cove. Inside the aluminium was roughed up and then cleaned with acetone. T88 epoxy was then used. Seems to make a strong bond.
Need to work on the plywood insert for each aileron cove next...still need to do some thinking about this!
