Brief Description: Flipped the upper wing and added aileron cove spru
Today I flipped the wing to be able to Clear Coat the under surfaces which I missed when coating the upper wing surfaces (thanks Kelly and Connor for your help!).
I added some 1/4"x 1/2" spruce to the lower rear spar in the aileron bay. This will be used to support the 1/32" ply that I will use in the aileron cove. It will be curved and attach at the bottom (using this recently attached spruce) and the rib ends.
