Brief Description: Built a jig to match drill the 1/4" bolt holes
Built a jig so that I could match drill the 1/4" bolt holes through the spars to locate both flying wire plates accurately. I simple design (found from the BP Forum) and it worked very well. I will also use the same jig to match drill the centre attach plates.
