Brief Description: Created a drag wire drilling jig
Created a drag wire drilling jig today. Built so that it could clamp to the work bench. Levelling was by laser level and shimmed to the correct height for each hole. It is sleeved with 1/4" ID brass tube and then a stainless steel tube of 3/16" ID was used which fit snuggly into the 1/4" tube. This jig, in combination with the laser level, was an ideal solution to drilling the holes for the drag wires. Simple but very effective!
