Brief Description: Grooving the drag and anti-drag blocks
Had to cut a 1/4" groove in the drag and anti-drag blocks for the rear upper spar. This groove is also at 6.5 degrees! I used a 1/4" router bit in the router table and firmly taped a wedge under one side then ran each block through. Seemed to work very well!
