Jon's Skybolt Project
Skybolt
Port aileron tip rib
Work started on the port lower aileron. Started with the tip rib and glued in-situ, checking for alignment.There will be a 10mm gap between the tip rib and the wing rib.
Lower port aileron tip rib glued
Skybolt Home
276
Rigging
226
Workshop
