Vans RV-8 G-JBTR
RV-8 Build Log
Electrics
4-26-2012
Trim Relays and LED Controller Trays
I nicked this idea from JT's website, who I think nicked it from someone else!
Net result is this is a space saving solution if you are heavy on electrics/electronics and sits on the centre section under the seat pan.
I have two holes in the seat pan above the trim relays (Matronics Governor Mk3) so that the speed can be adjusted without undoing ALL those screws!
The LED controllers are for the NAV/Strobes.
The wiring phase is now complete
Trim and LED trays
RV-8 Flying Log Home
RV-8 Build Log Home
4096
Electrics
Fibreglass
55
460
Finish
Freight
Inspiration
Panel
Primer
Registration
Research
Safety
Smoke System
Support
Test Phase
The Big Move
Tips
Upholstery
808
Workshop
Wrap Up
