Vans RV-8 G-JBTR
RV-8 Build Log
Finish
2-10-2012
Windcreen Bonding 2
Same process as canopy:
1) Roll over bar cleaned then scuffed with maroon scotchbrite and brushed clean
2) 1/8" spacers glued with superglue approx 3/8" x 1/4"
3) Taped in position
4) Canopy closed to check spacing good
5) Clamp in position then sika from aft side (unable to get gun in on forward side but plent of sik pumped into spacing)
6) Fitted a 0.032" tab at front (epoxy to windscreen and rivet to skin)
7) After cured for 48 hours > unclamped and cosmetic coat of sika after priming
See
Windshield Fairing
Spacers glued and primed
Clamped and sikad
Small tab on front
RV-8 Flying Log Home
RV-8 Build Log Home
4096
Electrics
Fibreglass
55
460
Finish
Freight
Inspiration
Panel
Primer
Registration
Research
Safety
Smoke System
Support
Test Phase
The Big Move
Tips
Upholstery
808
Workshop
Wrap Up
